2020-02-13
03:57 PM
2023-05-11
11:48 AM
Noemi Balogh
Solved! Go to Solution.
2021-10-26 03:38 PM - edited 2021-10-26 03:38 PM
Thank you very much for the report!
Twinmotion is a product of Epic Games, so unfortunately there's little we can help in this case. I suggest bringing up this issue to Twinmotion support for further investigation.
I hope the issue will be resolved soon!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2022-06-29 11:27 AM
im having the same problem but i can not find the twinmotion tab in rhino. can someone help
2022-06-29 11:34 AM
Maybe you need to ask in a Rhino forum?
And Rhino was not even mentioned in the previous posts, so how can it be the same problem?
This is an Archicad forum.
2022-06-29 11:44 AM
the problem is missing objects while importing the model in twinmotion. the answer is to unclick the "optimize the geometry" box and I can't find that because it's under the synchronization’s options which in the twinmotion tap in rhino which i can NOT find.
2022-06-29 11:48 AM
But this is an Archicad forum, not Rhino.
If you are using Rhino, you need to go to a Rhino forum.
Or are you saying you know where the setting is in Rhino, but you can't see the same setting in Archicad?
2022-10-28 04:27 AM
Hello Minh, I know this is an old issue, just installed all the latest twinmotion and plugins 2022 and dataexporters but I seem to see some missing parts. I dont have that "optimize the geometry" in the direct link settings.
2022-10-28 11:21 AM
The original post was talking about the 'Direct Link' add-on.
There is no 'Direct Link' add-on for Archicad 25.
You will have the 'DataSmith' add-on?
This may be completely different - I don't have it installed so can't say for sure.
