Visualization
Unable to install Cinema 4D Add-On on AC17 USA
Eduardo Rolon
Getting an permission error. Ideas?
Eduardo Rolón AIA NCARB
AC28 US/INT -> AC08
another Moderator
Marton Kiss
I am not sure if you are still dealing with issue, but this sounds like a permission problem.
A few ideas:
- run Disk Utility from Applications, Utilities
- Select the System partition
- Run Verify Permissions then Repair Disk Permissions if indicated
Also select your ArchiCAD 16 folder in Finder:
- right or ctrl click to get the context menu
- get info
- Sharing & Permissions
- make sure your user account has read and write privilege to that folder
- after making changes select the little cogwheel and apply it to all enclosed items
Let us know how it goes,
Marton
Marton Kiss
Chief Product Officer
GRAPHISOFT
Eduardo Rolon
Did fix it by editing the permissions for the whole folder.
AC28 US/INT -> AC08
another Moderator
Marton Kiss
Thanks, sounds good!
Marton Kiss
GRAPHISOFT
