Vectorial Shadows ?
Hi all - hope you can help
Brand new to archicad and still working with Autocad
A collegue has sent me a project in archicad with all shading already setup and at the moment i still need to export to autocad, but the shading makes a mess of it.
simple question then is how do i switch the shading off so i can export it simply
thanks
5 Replies 5
Could you please be more precise about what you exporting from ArchiCAD. Is it Elevation or Section views with the shadows on or something else? If so you may have to go into the 3D Window Settings and turn off the Vectorial Sun Shadows and then rebuild these views. More information required.
Gerald Hoffman
“The simplification of anything is always sensational” GKC
Archicad 4.55 - 30-Latest USA
2024 M4 Max MacBook Pro-OS Tahoe (128GB (16 Core CPU + 40 Core GPU)
hi - thanks
exporting elevations as a dxf file
select the elevation markers in floor plan, open properties, ctrl+t (default)
go down to model display box - tick off vectorial sun shadow
Thankyou very much - that did the trick !!
Now i need to learn how to use archicad, because the stuff i've been sent so far looks very impressive
Djordje
After selecting the S/E markers, find the shadows in the Info box, and turn them on.
You don't necessarily have to open the Settings.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
