ā2017-08-23
09:33 AM
ā2023-05-11
11:56 AM
Noemi Balogh
ā2019-03-13 06:16 PM
Paul wrote:You do know that Lumion has Live Sync with ArchiCAD for versions 6 thru 9 right? Instant feed back from what you do to the model in ArchiCAD and Lumion model on your 5K screen ( if you like). The only way to test Lumion 9 Pro is to request a trial and confirm that you computer is adequate to run it. It runs flat out FAST on my laptop. See specs in my signature. In this image, I stretched the terrain into these mountains placed all of these trees, made the lake, etc.... imported the ArchiCAD model ( you can tell by the crappy ArchiCAD trees) , clicked on a weather option, rendered this in less than a minuet. I suppose it took me an hour to get the get the terrain modeled because I was just goofing around with the program to see how it works. So easy. I would say it takes no training whatsoever. Play around with it for an hour or so and you are well on your way to using it effectively. I don't like the Lumion navigation system at all, but then anything that is different from ArchiCAD navigation will be awkward to an ArchiCAD user.
Nice image.
A physically unbiased GPU accelerated version of Lumion built into ArchiCAD, and able to export standalone viewable files (like BIMx, only a decade more up to date) would certainly be the ticket.
ā2019-03-13 10:42 PM
ā2019-03-14 01:50 AM
ā2019-03-14 03:59 AM
ā2019-03-14 11:00 AM
ā2019-03-14 11:34 AM
ā2019-03-14 12:13 PM
ā2019-03-14 12:25 PM
ā2019-03-14 03:35 PM
ā2019-03-14 09:47 PM
