Mats_Knutsson
Mentor
Where's the "oomph" setting?
I dig the white model renders but would like some more oomph...like a clarity filter in Lightroom. Which filter is it? I went lost in the jungle of settings and my Corona using colleauge didn't know it either. He got a perplex look in his eyes whe seeing the zillion settings.
/M
AC 25 SWE Full
3 Replies 3
Erwin Edel
Any examples of what you are trying to achieve?
A little post production ussually does the trick a lot faster than trying to get it rendered like that out of the box, in my experience, though.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Mats_Knutsson
Mentor
Here is a quickie. I just want more contrast and a clearer image and I don't want to post in PS. I just want to get rid of the milky feeling in the renders. I'm going to produce a bunch of presentation layouts with 9 images each so there is no room for post.
/Mats
AC 25 SWE Full
Erwin Edel
Go into the detailed settings.
If you want things to brighten up a bit, look at the physical renderer settings. The camera settings is just like actually camera: ISO, shutter speed, F-stop, but also white balance.
Under the Effects channel you can do some color correction with saturation, contrast and brightness.
You can even do vignetting.
Personally I would still go in to PS, even for 9 renders: I use adjustment layers to tweak to my liking, so I can just copy them around on top of the renders, it is faster than endlessly tweaking cinerender for me.
www.leloup.nl
