Why can’t I add these windows correctly?
There is something about this wall! I tried to a picture window on the main floor and a small ciircular window above it.
It allowed me to add the first window, but not the second. So I deleted the first one and added the small one up above. It allowed that but now won’t allow the original window to go in.
Scott
1 Reply 1
First thing I would check is that your renovation filter is not causing the issue.
Double check that the view, windows and walls are all set to the right filter.
Michael
