Windows Question ..... transparency & reflection
Hi guys..... I did the right thing....I did a search to see if someone had asked this question before..... so forgive me if I missed it.
I am wondering if it is possible to set the material of a window to be transparent from the inside....and just reflective from the outside?..... Is this something that can be done inside archicad or do I have to remap the UV's once I go into my 3D App?
Thanks,
Tom
2 Replies 2
Dwight
You'd hack the window object GDL code to allow separate materials on the front and rear of the glazing.
Ideal glass material involves using shaders, not maps.
Dwight Atkinson
K thanks...... I think I will just change my materials for the render..... its no biggie I guess.... thank you for your reply.
