Visualization
Wood Deck MATERIAL
Any one knows how to manipulate the size of the boards of the DECK MATERIAL?
The material is very neet, with a simple slab ArchiCAD represents the slab as 3D boards in Open GL or Internal Engine, the problem is that the boards are like 12" wide and I need to make them 5".
13 REPLIES 13
Erika Epstein
Options>Element Attributes> Materials.
If you option/Alt + click on the slab with the material the Material Attribute window will default to this material. Make a copy of the material and in the copy, named Deck material 5" or sim adjust the width the material repeat.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Hi Erika thank you. Have you used this material in paticular?(Wd-deck)
The material has some type pf GDL function in, that makes a continuoius slab show as separated boards when in 3D. I'd like to be able to configure the size of this boards. Thank you and regars,
F.S.
Erika Epstein
I'm not seeing the separate board effect in 3D.
Where did you get the material ?
What version of AC are you using?
Does it come from an Add-on?
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
Hi Erika,
This is in AC12, I do't know where this material came from because I tried to start a new file from AC12 Template and the available list of materials is way smaller (and Wd-Deck is not there).
And the weirdest thing is that after trying a lot of different things yesterday to try to manipulate de size of the boards the 3D function I was talking about is gone. I don't know what happened to the material, I've been trying unsuccessfully to bring the material to it original settings...
Thank you any way for your attention...
f.s.
Dwight
Could you please open that file and post screenshots of the magical material's dialog?
Dwight Atkinson
Some how the material lost the 3D capabilities?!... I don't know what I did, I spent like 1 1/2 hour trying to revert the material to it original settings but it will not work again as it was working yesterday morning...
Dwight
I sympathize with your dismay.
But if you post screenshots of the dialog, I can tell if it is a bump map illusion or not.
Dwight Atkinson
Unfortunately I haven't saved any screen shot when it was working, but I am sure it wasn't a bump map because this would happen not only in the rendering window but also in the 3D window (in internal & in open GL engines)
The slab would be shown as several separate boards in the 3D window.
Erika Epstein
don 't know if this is of help. but these are the settings for the Wd-Deck material I have, it's in a file from someone else and I don't know where he got it.
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
