Visualization
Wrong surface calculation in zone
I have ran to following difficulty: If I set "Add Wall Recesses to zones" in preferences, the calculated surface of a zone is totaly wrong. Only surface of the recess is calculated. Any idea?
Wellknown bug, I don't know if Graphisoft knows it though
Greg Kmethy
Luka,
Please send a small PLA to your local tech support. I tried (apparently) the same settings, but it worked OK. Might be a difference in the library part used, or god knows what. That's why we need exactly the same settings.
Thanks,
Greg
Gergely Kmethy
VP, Customer Success, Graphisoft
