Visualization
about making QTVR's...
looper222
i am having some problems with making qtvr's and am slightly frustrated with graphisoft's lack of documentation, maybe you all can help:
with VR objects: i currently have specified 10 parallels, which i understand shoudl be 10 vertical steps for the rendering (within my given lowest and highest view, in this case, -5deg and 35 deg). for some reason in the finished mov file it only gives me 3 descrete vertical steps. does anyone know why this happens and what i can do?
with VR scenes: i can make VR panoramas okay. but with scenes... what is meandar? i can find documents that tell me what it can do, how to use it. but where and what is it? thirdy party software? what the?
thanks,
carl
5 REPLIES 5
MMontgomery
The 10 parallels are how many you would get if you were using all 90° (0 to 90 rather than -5 to 35)- so since you are only using roughly 1/3rd of that, you only see 3 steps. Increase the number of parallels to 30 or 35 and try it out.
AC 6-29 - Ryzen9-9950X / 96GB RAM / RTX 5090 / Win 11 Pro
It is actually the number of parallels in 180°. From straight up to straight down.
You always will have one at the upper and lower limits of your view. The overall number is used to determine how many intervening steps you will have.
looper222
thanks... but what about that meandar thing...
Food for thought, here is how I currently do it. Quicktime vr rendered with 3ivx or Divx5.1. Cinema4D. 46 frames. One level.
Folder at:
http://www.Burginger.com/ARCHICAD_TALK/VR_TEST
Divx = smaller
3ivx = Better Quality, especially shadows
Djordje
Take a look into the Meander folder in your ArchiCAD installation folder.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
