2008-04-1011:52 AM - last edited on 2023-05-1101:09 PM by Noemi Balogh
2008-04-1011:52 AM
hi, i'm using artlantis 2.0 and archicad 11.
i can export archicad model in artlantis with no problem. but whenever i click on shader or object artlantis will crush why?
but if i load the file with artlantis 1.2 there will be no problem......
If my information is correct Graphisoft is currently testing the new plugin AC11 to ArtLantis 2. At the moment you can only export to ArtLantis 1.2. The plugin will be available soon.
For a workaround it is suggested to export to 3DS if you want to use your files in ArtLantis2.
If a file is giving you too much trouble then you can send an ACarchive to Abvent. They will study your file and bring a solution
oh! maybe thats why, but i have discover that the crush happen because of run time error...and for some reason....exports from sketchup wont even work now (export from sketchup do work before this incident)........so i guess i will just go back to 1.2...and wait........
