Learn more
artlantis crashed!!!!!
hi, i'm using artlantis 2.0 and archicad 11.
i can export archicad model in artlantis with no problem. but whenever i click on shader or object artlantis will crush why?
but if i load the file with artlantis 1.2 there will be no problem......
why????
4 Replies 4
Penicillin
If my information is correct Graphisoft is currently testing the new plugin AC11 to ArtLantis 2. At the moment you can only export to ArtLantis 1.2. The plugin will be available soon.
For a workaround it is suggested to export to 3DS if you want to use your files in ArtLantis2.
If a file is giving you too much trouble then you can send an ACarchive to Abvent. They will study your file and bring a solution
Success Sjaak
oh! maybe thats why, but i have discover that the crush happen because of run time error...and for some reason....exports from sketchup wont even work now (export from sketchup do work before this incident)........so i guess i will just go back to 1.2...and wait........
Djordje
Definitely send the crash report files to Abvent; the link is on the Abvent site.
Personally, I have not had any problems in using the 1.2 files exported from 11 in 2; and the SketchUp plugin did misbehave ocassionally ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
On the ArtLantis website the Export add-on from ArchiCAD 11 to Artlantis 2.0 is available for download.
The add-on is declined in 3 categories MacIntel, MacPPC and Windows.
http://www.artlantis.com/index.php?page=download/plugin/index
Sjaak
