Eevastiinaj
colour selection box dysfunction request 179711
As you can see the box is partially visible and I can't select the colours anymore. I have restarted all multiple times.
Dear Eevastiina,
Thank you for your question! Unfortunately, we don't solve technical issues like yours on this channel.
For technical questions, check our Graphisoft Community, where there are a lot of Archicad gurus to help you with technical questions.
All the best,
Giovanni Logiudice
MyArchicad Support
Issue still remains.
Operating system used: Windows 26.0.0
1 Reply 1
Do you have your windows screen scaling set to 100%?  Any other setting can result in problems like you show.   Also is your display driver (and all Windows Updates) up to date?
To clarify about technical questions… the answer you received to ask here is because you have a free educational license, which offers no technical support,   This community is not technical support either… but often someone here can help solve your issue,
