We value your input!
Visualization
exporting from AC12 to artlantis 1.2.6
Can it be done? I get the canned response (cannot write output file) Really not interested in upgrading to artlantis 2.0 for a 1000 bucks.
21 REPLIES 21
Dwight
So, save backwards to 9 and then to Artlantis.....
or use the free Artlantis demo until it seduces you.
Dwight Atkinson
Hey dwight! Thanks! Well, I tried saving it down to 11, but got an archicad bug report, my suspicion is that it doesn't like the archicad 12 library parts. The new artlantis would be nice, although with the current workload, I cannot really justify it. Maybe abvent will go bankrupt and then archicad can buy them and then make it the default render-er for archicad! Here is for hoping!
Dwight
There are some tiresome resentments that persist when i do traveling lectures:
- users resent the need for Photoshop to make better renderings.
- that Artlantis represents a fantastic value of ease of use, predictability of result and speed of production now that the import/export and object editing issues are resolved. Archicad users can't go wrong with Artlantis.
Even if times are tough right now, it is a chance to practice with the new software for later when things get busy again and you can really make some money.
Dwight Atkinson
Of course - you have the option in the Save As format list (attached).
The error message you receive is due to one of two things: (1) a zero height wall [discovered by Djordje], or (2) material names that contain non alphanumeric symbols. Certain symbols are allowed, others result in the error. Yes, Abvent should provide a better error message with the name of the problem material ... or else accept all names. See the Artlantis forums for more discussion of this error and how to solve the export.
One of the forum moderators
AC 28 USA and earlier   •   macOS Sonoma 14.7.1, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Thanks Karl,
I will check the material names, I might even try to exclude them. I will report back my findings. I doubt I have one, but I will use find and select to search for a zero ht. wall.
cheers,
are dashes (-) or inches (") allowed in material names, I also have spaces too? I am using the stock archicad 12 file, with some of my own textures. I opened the 3d window with all the layers on and did a find and select for a zero ht wall, and found nothing. I am now wishing I was able to save it down to 11, which I tried and the library parts don't appear to work
Dashes are OK, but I'm not sure about inches/double-quote. (I think it works now - it was a bug I had reported back with Artlantis 4.0 / 4.5)
How about just starting a fresh file with just a wall and slab or something simple, displayed with standard materials that have no textures associated with them to see if that works for you to verify that the connection is generating a proper 1.2.6 file? And, then try some of your other materials to the same simple model, etc... Then you'll know what to do for the real project to work.
Good luck!
Oh dwight,
Sorry for the delayed response. Yes, I should practice on it, and in a few months maybe 1 grand won't seem like much. .........or worth that much.
I have tried everything!!!!! Nothing will allow me to export this file. I have been banging my head against a wall trying to get this silly thing to work. I have been able to export another file to artlantis without issue. Does the new version of artlantis have this issue? Can someone export this for me into the new version and then save it down for me? HELP!!!!!!
