Visualization
floor plan cutaway
is there a way to enlarge the building image in the 3d cutaway window so i can place the cutaway more accurately?
Dwight
ello, bruce! Is the sun still white down there?
On mac, you just pull the bottom right hand corner to enlarge the window.
Before this was possible, we went into the program code and redefined the window size.
But for real accuracy, use coordinate inputs.
Ba do, ba ding.
The special menu seems distant, if not impossible, these days. How i miss using the analytical section tool in 3D.
Dwight Atkinson
<<Bright golden white - when it is not overcast or raining!
<<Well this works a bit but the house is still too tiny.
<<I tried this but it did not seem to take them! Must be doing something stupid I suppose.
<<Now we are getting into morbid reminiscencing...and I can scarcely recall that!!
