how to make bamboo material textures?
Help me to make bamboo texture, because i'm not found bamboo texture on Archicad 11. in Indonesia, specially Java peoples, they very familiar for using the bamboo for they houses. I has been tried to make design of a house, but i can't make bamboo for my design structure.
13 Replies 13
thank you Mr.Dwight for your sharing, i will try it.
great regard from Jogja, Indonesia
lhalaact
Lhalaact!
If you're short on time and use bamboo a lot (which I imagine you might) There is a 3D GDL object available at Objectsonline:
http://www.objectsonline.com/product_info.php?products_id=7271
There is a small charge (28USD) but I reckon for quality of out-put, rendering time and effort it must be worth considering.
thanks for your info
Hi Lhalaact
Heve you ever got into the final texture of bambbo? I'me looking for a unit of bamboo model to use on a project but I can't find none nor know how to do it. Can you send me a copy of your model if you really got into it?
Still, do you have models of bamboos plants that I can use for exterior decoration on a project?
I thank you very much for such help
Luís
