Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
Visualization
Render your model with built-in or 3rd-party solutions
import textures
Hi i have download some textures (stone walls - tiles) of arroway but i don't know how i can put it in archicad 11 so i can use it, and looks my project more realistic. Any help? thanks in advance !
4 REPLIES 4
load the folder with the images with the library manager.
You will also have to assign textures to Materials for them to show in 3D.
Hi, Im using the new archicad 12 and I import some new textures from archibase.net. I can see it in my 3D model but when I renderize it in Lightworks, it only appears the colour that I duplicate to put the new textures. What can I do to see the new textures in my renders?
Thanks
Thanks
See:
http://archicad-talk.graphisoft.com/viewtopic.php?p=130630&highlight=match+internal#130630
AC 29 USA and earlier   ā€¢   hardware key   ā€¢   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
