2003-11-12 12:30 PM - last edited on 2023-05-11 02:40 PM by Noemi Balogh
2003-11-13 08:03 PM
2003-12-05 03:43 PM
archibaldo wrote:Good tip,
if you press CTRL in artlantis (in the creating new light window )the next light created will have the same settings with the previous
P.S. if you want to activate the special menu in artlantis you must do this :
in edit shaders menu window keep press SHIFT and in the same time type the next text
((EXPERT)
and you will see a most complex shader editing menu
to activate another special hidden shader menu you can
tipe a second command
((MNSHADER)
2003-12-05 08:37 PM
archibaldo wrote:Archibaldo,
be carefull NOT to edit in the text processor (uedit.32) even the
artlantis.exe file or TXTEXTENSION file
