Visualization
lights in Art*lantis 4.0
how could i select more than one lights and change the settings just one time for all?
12 REPLIES 12
be carefull NOT to edit in the text processor (uedit.32) even the
artlantis.exe file or TXTEXTENSION file
BY THE WAY TODAY YOU HAVE JUMP BETWEEN Art*lantis 4.0
TO Art*lantis 4.5
CONGRATULATIONS
EDITING THE LIGHTS IS SIMPLE :
RENAME THE PREFFERED LIGHT TO EASY REMEMBER OPEN THE SAVED FILE LIKE A TEXT FILE WITH A TEXT EDITOR FIND THE LIGHT AN HIS SETTING COPY AND PASTE THE SETTINGS TO ALL LIGHTS IN THE FILE
archibaldo wrote:
if you press CTRL in artlantis (in the creating new light window )the next light created will have the same settings with the previous
P.S. if you want to activate the special menu in artlantis you must do this :
in edit shaders menu window keep press SHIFT and in the same time type the next text
((EXPERT)
and you will see a most complex shader editing menu
to activate another special hidden shader menu you can
tipe a second command
((MNSHADER)
Good tip,
The first ((expert) worked the second one didn't. How does that one work?
Virtus
Jacek
Archibaldo,
a little off topic, but I can't help noticing - you must work out a lot...
Jacek
jacek lisiewicz
arkhos-tekton, architects
carmichael, ca
Mac OS X 10.15.5
IMac Retina 5K, Intel Core I7
32 GIG Memory, AMD Radeon R9
ArchiCAD 24
