Visualization
lightworks - alpha channel issue
having some issues with rendering a library part with an image map (incl alpha channel)
as you can see from the attached... the alpha appears to be working.... but for some reason i cannot seem to get rid of the grey-ish translucent-ish background
any help would be greatly appreciated
this has been rendered in archiCAD (lightworks)
the alpha channel etc seems to work ok using the internal rendering engine
thanks in advance
undefined
11 REPLIES 11
Dwight
what rendering quality and antialias level are you using?
Dwight Atkinson
dwight
thanks for the quick response
i believe that both are set at max
any thoughts?
thanks again in advance
Dwight
here's my experience with the lioness image - no problem.
undefined
Dwight Atkinson
dwight
weird... all looks great with your rendering
is it possible to copy and paste the gdl from the object that you have used (or attach it so that i can download).... that way i can check it against what i have.... maybe i have screwed something up (though there is not much to screw up here i would have thought)
thanks again for all
Dwight
ParaPicture.gsm
Dwight Atkinson
dwight
wow.... you don't muck about
thanks very much for dealing with this so expeditiously
i will give this a run and report back
thanks again
Dwight
ask a busy man. everything is at his smoking fingertips as they stroke melting keys.
Dwight Atkinson
smokin' you are
loaded the library part... re-rendered.... NO issues
i checked thru my script and yours... identical (where it matters).....very weird
i guess it is just one of those things
thaks again for all your help on this
i am off to populate my space with lots of "pictures"... with lovely... working alpha channels
GDL Picture no generate shadow
czech GDL object generate shadow and rotate to camera (rebuild 3D)
