Visualization
luminance material and lumen
alemanda
Hi!
Is there any relation between the strength of the luminance channel and the intensity of the light in terms of lumen?
eng. Alessandro Mandala - Italy
AC27 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores) - 32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 2560x1440
Erwin Edel
Surfaces only have a 'glow' sort of postproduction effect, they do not actually light up a scene, as far as I know.
I tried faking a night scene with surface casting light, doesn't work that way, sadly.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
alemanda
Sorry ...
probably I made a mistake.
look at the attached picture.
I was referring to the surfaces producing lighting ...
I would need to know the relation between the value 100 (is expressed in percentage) and the lumen ... if any
AC27 latest hotfix
Win 10 Pro 64bit
