2005-06-22 04:00 PM - last edited on 2023-05-11 02:17 PM by Noemi Balogh
2005-08-22 05:21 PM
oreopoulos wrote:Maxwell's plugins are freeware
yes. It is rather uselless at the moment.
Just a geometry exporter in maxwell's native format.
When it will be usable i will post an update
2005-08-22 06:02 PM
2005-08-23 08:27 AM
zucoc wrote:But Maxwell renderer is not...
Can you share yours?
2005-08-23 08:39 AM
2005-08-23 09:09 AM
oreopoulos wrote:Possibly, but the beta and alpha versions of VRay and Brazil (starting as 3ds max plugins but getting independent) were free and once the commercial version was finished, they offered both a free demo of the commercial version and a limited freeware version (usually non-commercial).
maxwell is not a final product yet, so there cannot be a demo.
I guess there would be a demo asa it is released. (whenever that is)
2005-08-24 09:46 PM
stefan wrote:The difference is that unlike Vray and brazil, Maxwell renderer is not a plugin but an independent command line application that runs outside the host program ( Max, Maya, Cinema 4D etc). The Maxwell plugins are only model converters that convert the model into Maxwell's mxs format and then open the render engine itself in a separate window to initiate the render. Vray and Brazil both run within their host program ( Max) and hence are not stand-alone engines per se ( they both ahve plans for stand-alones coming this fall, but until that changes, you can't run neither without Max). Consequently, that may have something to do with the reason why they can offer free public demos and Maxwell can/does not.oreopoulos wrote:Possibly, but the beta and alpha versions of VRay and Brazil (starting as 3ds max plugins but getting independent) were free and once the commercial version was finished, they offered both a free demo of the commercial version and a limited freeware version (usually non-commercial).
2005-08-24 10:16 PM
2005-08-24 10:26 PM
2005-08-24 10:30 PM
oreopoulos wrote:
its not that simple, but better not get into that discussion
2005-08-25 10:01 AM
