paving slab texture required
has anyone got a texture of paving slabs, i've scoured the net and the archicad libaries with no luck. theres plenty of block-paving textures but none for paving slabs?
4 Replies 4
Dwight
Try the Lightworks shader archive in the architectural archive section.
Materials>Construction>Concrete
This concrete paving is essentially using the textured brick shader at a large size.
You can make it rougher to your taste with the displacement shader.
Be sure to duplicate the existing material - also give it a new name - before going into the archive or whatever you select will over-write the existing material.
Dwight Atkinson
have you got a link to the architectural archive?
Dwight
You already have the archive in your material dialog. "Load from Archive."
Just remember to duplicate the material you are in before spelunking in the archive or risk inadevertently over-writing that material.
I've taken the data in the LightWorks archive and made them into materials for Archicad users who bought my book.
Dwight Atkinson
ah yes found it now cheers.
