publishing jpeg
how can i create a high quality jpg directly from archicad. presently, i am publishing to plotmaker, and from plotmaker, i am publishing to photoshop as an eps file and then creating a jpg from that. if no one has any ideas on how to generate a clear jpg directly from archicad, does anyone have any ideas on how to cut down the number of steps/programs in my process?
thanks
10 Replies 10
if U still want to make jpg's from plan view in higher dpi instead of using pdf format;
zoom in a lot! before saving as jpg.
You don't have to see everything in view to make sure it ends up on your jpg as long as the layers are visible.
Then use the Save As command or clone all plan views with the same zoom to be able to "batch" save jpg's
