‎2006-06-11
10:04 AM
‎2023-05-11
02:10 PM
Noemi Balogh
‎2006-06-12 04:22 PM
‎2006-06-12 05:10 PM
laszlonagy wrote:Thanks
If you save from AC10 as AC9 and you are using AC10 Library Parts, you will lose them in the resulting AC 9 file, so you will not be able to create the same 3D Model to save as Artlantis from.
You should watch out for this.
‎2006-06-12 06:15 PM
chrispy wrote:I can recognise the difference betw. sky object and realistic sun.
In AC 10 also check out the realistic sky shader. It can be found in the Library:
Lights, LightWorks Lights, Sky Object, in the settings at Sky Object Type choose Realistc.
‎2006-06-12 07:25 PM
‎2006-06-12 07:37 PM
‎2006-06-12 07:48 PM
‎2006-06-12 07:55 PM
‎2006-06-12 07:59 PM
Dwight wrote:Sorry your USA version is ok.
Could some others please confirm in what trading areas on Earth the Sky Object wirh Realistic option is provided?
Or is it just the Germans who get it before the rest of us, again?
My USA version Sky Object looks the same as last time.
‎2006-06-12 08:37 PM
Dwight wrote:Check that you've got the right library loaded. Some have reported that AC10 sometimes loses track of its History in Library manager.
‎2006-06-12 08:49 PM
