Visualization
render but changed material not appear
I'm changed material by option / 'element attributes' / materials / texture.
In 3D view 's change but when rendering 3D It's not appear. Please help me . I want to have more material's surface. How can i make it?
1 REPLY 1
That only changed the texture for the internal engine. If you are rendering with LightWorks, you have to switch to LW settings in that same dialog and click the button "Match to Internal".
See:
http://archicad-talk.graphisoft.com/viewtopic.php?p=134488
http://archicad-talk.graphisoft.com/viewtopic.php?p=130630
http://archicad-talk.graphisoft.com/viewtopic.php?p=134226
Karl
AC 28 USA and earlier   •   macOS Sequoia 15.4, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
