2010-12-06 11:55 PM - last edited on 2023-05-11 02:20 PM by Noemi Balogh
2011-01-11 07:57 AM
2011-01-11 02:38 PM
2011-01-12 01:57 AM
2011-01-14 11:24 PM
2011-01-15 01:53 AM
Foster wrote:You could make the dome by careful arrangement of a camera path. Of course you would have to make several for different diameters and numbers of lateral paths. The frequency of the images could be controlled by the number of shot between keyframes.
I do have a potential solution, but first wanted to chime in and moan that the loss of QTVR is tragic; it was just so easy and quick to make, and it controlled what the client was allowed to see. I have not yet moved to version 14 because of it.
As to the solution, I have an idea for it but would need some help/answers in certain areas. At a previous job, I used to work on 3D spins for products, but through photography rather than rendering. Products were placed on a table that spun 360 degrees, and a photograph was taken a intervals in one plane, then re-adjusted to another plane/viewing angle and spun again. The end result was a folder full of images taken incrementally, and then filenaming reflected this. Then, all these sequentially named files were dumped in a Flash file, which was programmed to spit out a shockwave file that is more or less the same as the QTVR which we all love. You can spin the product/model, and zoom.
I may be able to create a Flash file which is automated to create a spin as long as the user pays attention to filenaming. The problem is getting ArchiCAD to spit out all the images. As far as I can tell in version 14, we are no longer able to use the "Dome" like before. Am I correct in assuming that it no longer exists? If so, then the only choice is to create a Fly-Thru... But it seems that it would be cumbersome to try to set up a fly-thru to act like the Dome used to... The Dome was quick and easy with all necessary settings in one dialog box, rather than adjusting a bunch on cameras individually.
So what I essentially need, is to somehow get the Dome re-activated in ArchiCAD, but for the output, I would need it to just spit out individual png images in a sequential order. I imagine that is what QTVR did, except that Quicktime packaged them all into one final Quicktime file.
Reading what I just wrote, it's sounding impossible. Any thoughts on if Graphisoft or one of you other wizards out there can revive the Dome to ouput images? If so, I would be able to provide a Flash template which can create Spins.
Foster
2011-01-17 09:46 PM
2011-01-18 01:31 AM
2011-01-18 05:26 PM
