Visualization
Render your model with built-in or 3rd-party solutions
sketch Line Shadows - Do not match Physical sky shadows
I am trying to make a graphic with sketch lines and rendering merged but the shadows do not align. Any suggestions?
2 REPLIES 2
I have used that technique before but turned off the shadows in the sketch render. Makes the sketch render a lot quicker, and the shadows from the photo render do the job anyway.
But, have you made sure you have "use Archicad sun position" checked in render settings?
Yes, I did have "use Archicad sun position" checked.
I too have done it as you described but for this particular project I wanted the shadow in the sketch render.
I will have to tweak the sun for the sketch render at the moment until it seems to overlay correctly.
