Visualization
spot light 18 ?
Is there a way to turn off the arrows and cones that show in open gl for each "spot light 18" without having to go into each lights dialog box?
I want the lights and the effects to be there, but not the wire frame indicators.
Of course they go away photo rendering or Cinmax, but they are messing up
my open gl views that are placed in many places throughout my set of drawings.
I made the mistake of putting them all on the same layer as the recessed cans.
Hoping there is a show / hide option somewhere that I can't find.
David Maudlin
Jonathan:
1. Turn on only the Lamp's layer.
2. Use Filter and Cut Elements in 3D to show only Lamps
3. Use Find & Select > Element Type is Lamp, Name is Spot Light 18, select the Lamps
4. Open the Lamp Settings and change the parameters for all the Lamps at once.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thanks David, I'll give it a go. I was hoping there would be something similar to the hide text handle solution.
