texture help
My boss want to see a tile look on part of wall before the rendering. Is it possible to make this happen?
How do you put texture on part of wall?
There are a couple of ways to do this. Do what ever is easiest and understandable first. First go to image>3D window settings and in the effects turn on vectorial 3D hatching. With this on, a material that has a 3D hatch will show in the 3D window.
You can make two walls siting on top of each other, upper wall one material the lower wall a material that has a tile 3D hatch.
or
Make your wall, select the wall click on extras>accessories>wall accessories, find an object called moldings and panels. In here, change the geometry to suit you need and change the material with something that has a 3D tile hatch, click ok. Check what you have in 3D.
There are other ways to do it. These are just example of what you can do. Try different ways of showing what you to find what is easiest and fastest for you. Hope this was helpful
Thank you for your help. The only way, I can think is put one wall on the top of the other wall. Thank you for giving me other option to try. I think it can save me some times. I cannot image how many little wall I need to make if I do it in my way, because the texture is tile.
