texture map location?
Does anyone know how to locate the actual .jpg files that are in the library? I'm on 19.
For example, I'd like to open an existing jpg. of brick and modify it in photoshop slightly.
I can see all the jpg files from within the image library of archicad but when I browse to the library folder all I see is a surface catalog 19.Icf file.
Any way to access these?
See this link about how to open the file via AC and save a new copy:
http://helpcenter.graphisoft.com/guides/archicad-20/archicad-20-reference-guide/elements_of_the_virt...
Background info on LCF:
http://helpcenter.graphisoft.com/tips/archicad/library/where-are-all-the-library-objects/
You can un-archive the entire LCF, too, but unlikely you'll need to do that.
