‎2009-05-21
01:14 PM
‎2023-05-11
12:56 PM
Noemi Balogh
‎2009-05-21 02:17 PM
‎2009-05-21 02:29 PM
‎2009-05-21 03:02 PM
Peter wrote:thanks peter, this is what the pdf says, perhaps i just need more practice:) i just find that either way i do it i dont get the desired effect...
Firstly, thanks to PB for stepping in to help!
Making a thatch texture is probably the easiest type of texture to make as it is fairly simple and random, and so it is a good example to start to learn with.
For future reference, when extracting a portion of an image from a photo, in Photoshop use 'Filter' > 'Others' > 'Offset' to shift the image over so you can see the opposite edges of the texture next to each other. Make use of the clone tool to sample multiple small areas of texture each side to hide the join. It's all fairly easy to do.
Hope that helps, good luck!
‎2009-05-21 03:20 PM
kylemotto wrote:No problem! If you want, post the original image up and I'm sure someone will take a look at it and give you some advice about the best way to do it.
