2012-10-12 08:50 PM - last edited on 2023-05-11 12:55 PM by Noemi Balogh
2012-10-23 04:38 PM
2012-10-29 10:13 AM
Mark wrote:
what graphics card are you using? check that it's compatible with OpenGL - I'm you'll have done this already though. you could also try fiddling with the settings in the work environment - in Archicad, go to Options>Work Environment>Advanced Redraw Options. or try checking the OpenGL options under the 3D window Settings dialog. it does seem to me to be a driver/compatibility issue as it's not a consistent problem.
2012-10-29 01:44 PM
2012-10-31 05:48 PM
bolsen wrote:After making sure you updated the OS and video card drivers, also check to make sure that your ArchiCAD settings and display settings under nvidia's control panel are the same with the settings on the machines where there are no issues. If all steps don't resolve the issue - you mentioned that you have identical machines, I would take this opportunity to swap video cards to verify if the video card is at fault here.
Nvidia Quatro FX580. I will try doublecheck the Archicad settings again but last I checked, they were identical to another machine that was running smoothly.
The problemisconsistent. It fails to render textures initially, then works after a screen move, then fails again after opening a new drawing.
Thanks for your reply. Any other ideas?
2012-11-01 01:09 AM
2014-03-16 08:23 AM
2014-03-16 08:24 AM
