ā2004-04-21
12:29 PM
ā2023-05-11
12:42 PM
Noemi Balogh
ā2004-04-21 01:18 PM
ā2004-04-21 01:59 PM
ā2004-04-21 02:13 PM
ā2004-04-21 02:21 PM
ā2004-04-21 02:26 PM
ā2004-04-21 03:06 PM
ā2004-04-21 03:14 PM
ā2004-04-21 08:07 PM
jazzdude wrote:When saving a revised model from ArchiCAD, save with template, using your last saved Artā¢Lantis filer as a template. You can choose what cones from ArchiCAD and what comes from Artā¢Lantis, but the geometry comes from ArchiCAD always.
I have just finished an artlantis render file on an archicad model and now see that i must add a couple more components,
Is there a way that i can make the changes in archicad and re-open it in the artlantis file with all the rendering settings intact?
ā2004-04-21 08:09 PM
gobel wrote:Hm? Isn't it easier to select only the new objects and save from the 3D window? Or hide all the layers excapet the one containing the objects you weant (provided they are all on the same layer)? Only what you see in the 3D window is saved.
i return back to the archicad file and i add the object that i want to add.
then i delete all the other object and i leave only what i want to add in art-lantis. Then i save it as a vew art'lantis file.
