lasse
v19 Sketch Render bug ....or....WHAT????
Model looks fine in OpenGL preview, cannot see a result when I render as a whole image, just a blank render using any sketch setting engine (no error messages).
When I pull it apart (in my attempt to deduce) the issue, I can render the left, center and right portion with some overlap, but not the unit as a whole. Any suggestions?
I've had success in v19 on other smaller massings using sketch, and this one isn't too detailed by my typical standards, but somethings up......
(unnerved by updates since v.4.55)
13 Replies 13
There was an update for ARCHICAD (build 4006), which was mainly a compatibility update with Mac OS X 10.11:
http://www.graphisoft.com/downloads/archicad/updates/AC19/AC19-3003to4006-ReleaseNotes.html
In its release notes I do not see any Sketch Rendering related fix or improvement:
http://www.graphisoft.com/downloads/archicad/updates/AC19/ImprovementsList.html#4006
So we will see if any news comes with the next update.
vfrontiers
Just want to SECOND the notion that my renders are producing BLANK FILES as well... I did a Session yesterday using the PATH to generate 5 views from the SKETCH RENDER WINDOW.. 2 worked, 3 didn't...
Of the ones that DIDN'T work, they also don't work when rendering individually.. I tried reducing the final output size, but that didn't work either...
I also tried restarting the computer, that didn't work either...
I, too, would like to get this back into the workflow...
Duane
Visual Frontiers
AC3.14 - AC29
:|: Enscape4.16:|:TwinMotion
vfrontiers
.. they also don't work with RENDER MARQUEE
Duane
Visual Frontiers
AC3.14 - AC29
vfrontiers
Just FYI, upgrading to 4011 seemed to "fix" for now...
Duane
Visual Frontiers
AC3.14 - AC29
