Visualization
vanishing hatch in sketch
David Bearss
I am a bit baffled by the results of the two attaches renderings. I am using the sketch render engine to develop artistic composite plans. However the hatch surface texture disappears when i place some furniture over it. This odd behavior does not happen on the floor below. All rendering settings are identical as I basically relocate the furniture off from the deck and the surface texture appears normally. Will keep fiddling but would appreciate advice.
Regards,
David Bearss
Archicad 28/Windows 11
Alienware 17 R5
i7 2.4 GHz / 16 GB ram
David Bearss
Here is same render with furniture moved
David Bearss
Alienware 17 R5
Erika Epstein
This is Archicad's new aesthetic clash detection system. The furniture does not go well with your design.
Just kidding.
Does the same happen when you put furniture on top of the tiled area?
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
