Visualization
what is your favourite rendering setting?
i use the internal lightworks rendering engine for rendering (because i don't have altantic, or 3ds max right now)
what is the best setting for the rendering to be a little bit real?
8 REPLIES 8
__archiben
File>Save As...>Artlantis Render Studio File 2.0
b e n f r o s t
Dwight
Answering that question takes an entire book.
Order "LightWorks in Archicad" now.
Dwight Atkinson
what content do this book cover???
Dwight
If you are rendering in LightWorks, this is your bible.
It has updates for Archicad 10 +11+12
Dwight Atkinson
i want to buy , $115 USD? how about shipping to Hong Kong???
and i found the content
http://www.entouragearts.com/Books/ArchiCAD/contents.pdf
Dwight
shipping included.
Dwight Atkinson
Hi all,
I would like to extend this question and ask Dwight. There are cases when you have done some succsessful renderings in the past and now want to get same rendering result in new file. What is the best way to go?
Should I just import (replace) attributes (materials) from older file and copy rendering settings (manually?). Will the older versions materials work the same way under AC12? Thanks
Dwight
Lighting changed since version 9.
Better shaders can be made since version 10.
My opinion is that every rendering is unique.
Dwight Atkinson
