Due to a scheduled maintenance, a maximum 20 minutes license delivery outage may be expected on July 6 2024 (Saturday) between 6PM to 8PM (CEST).
Wishes
It's improtant to Improve or perfect GDL Function
GDL is good at describing geometry object, yes, it's quite good. But there are lots of things we have to do is no-geometrical. For example, variable type convertion.
We can convert a numeric variable to string type, but we can not convert backward. So we need tips and tricks to walk around. It's too desponding.
4 REPLIES 4
I agree that some more string functions would be nice to have. I have ended up doing some curious bits of code to parse text and such like in GDL. I even had to make a word wrap routine for a special note symbol. THAT was a challenge.
While I'm on the subject, I have often thought it would be nice to be able to include an editable text field into a library part (like the text part of a label or dimension) so the user could type direcly into it instead of having to open the settings dialog. Now that we have the new interactive hotspots (HOORAY) maybe this could come sometime too.
Matthew Lohden,
Mmm, what you said is just what I feel.
You know, I come from China. I am not good at English. Sometime, I don't know how to express my feeling.
Not only string function, but also environment function, I/O function...etc. I think AutoLISP is better in these aspects.
I think Graphisoft should make GDL more like a programming language, not only a script.
Aussie John
Not quite the same thing but I an object I use a lot is a just a cube ( rect in plan) that uses the object ID as its text describer.
Cheers John
[/size]
I've been doing that for years but it's only 15 characters max. Not quite enough for any but very short notes.
