Due to a scheduled maintenance, a maximum 20 minutes license delivery outage may be expected on July 6 2024 (Saturday) between 6PM to 8PM (CEST).
Wishes
Publish IFC using IfcSpatialZone class instance
davdelven
Hello,
I wonder why the class IfcSpatialZone appears in the IFC Schema when setting up the Property Mapping in IFC Translator, if you cannot generate any geometry and map it to that class using the Type Mapping setting.
https://standards.buildingsmart.org/IFC/RELEASE/IFC4/ADD1/HTML/schema/ifcproductextension/lexical/ifcspatialzone.htm
On the other hand, you can export any geometry to IfcSite using the Type Mapping, and this class is a subtype of the IfcSpatialStructure, sibling of IfcSpatialZone sharing the same SuperType IfcSpatialElement.
The advantage of using this Class IfcSpatialZone is that you can attach a geometry into an independent spatial structure, not following the hierarchy of IfcSite>IfcBuilding>IfcBuildingStorey. We have several situations in which we have to inform about such those spatial structures, i.e. safety volumes, urban planning constraints, etc...
As we know, IfcZone is just an assignment, therefore a group of IfcSpaces, but there is a lack of own geometry, just the addition of Archicad Zones geometry.
So, my wish is to be able to instantiate IfcSpatialZone when publishing using the MVD IFC4 Reference View from Graphisoft Archicad.
Kind regards,
David
David Delgado Vendrell
http://www.daviddelgado.cat
i7-7820HK CPU 2,90GHz 32GB RAM
Triple Monitor 17"+25"+32" Nvidia Geforce GTX 1080
SSD+HDD, Win10 Home - 64 ENG
AC18-AC26 INT/SPA (64-bit, latest build)
Surfing with Archicad since 2013
3 REPLIES 3
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Hi All,
Thank you very much for creating this poll, and for those of you who voted to express their opinion.
I am happy to say this is an existing wish in our Wish List database (please refer to it as Wish #12368). Hopefully, our Product Management team will adopt this one in the future.
Thank you all once more, and I wish you a great day!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
davdelven
It sounds great, Minh!
Thanks for notifying it.
Have a great day, too.
davdelven
Hello, Minh
I am currently also participating in the IfcSpatialZone Working Group of buildingSMART International, moderated by Gianluca Genova.
Probably someone from the WG already contacted Graphisoft in regards to this topic. Anyway, let us know which is the current state of this implementation from the GS side.
Kind regards,
David
