Even though folders remain underdeveloped with their true management potential unrealised there are still seemingly small things that could be done to make folders at least useful for organising.
One of these is the ability to set folder level rules for automatic name and ID for items. As per usual the value of this is already acknowledge by someone somewhere but inconsistently implemented. It is quite ridiculous to have such functionality already implemented but still having to manually rename items to indicate their place in the structure.
Combine the naming function implemented for publisher sets and the identification function implemented for layout subsets and make it consistently implemented for every and all folders/groups structures in AC.
Not only would it make it easy for users to organise the project as they see fit but together with improvements to the search syntax it would not take more than a few keystrokes to get to an item.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
