How hard would it be to add a "lifespan" property to all elements in Archicad, which would define when the element comes into existence and when it's being removed from the model?
This would enable having a flexible multi-phase project approach, where the display of an element like wall or window would also depend by the point in time when the plan "snapshot" is taken.
Now, some will say that this is already possible by simply using a combination of Layers, Properties and Graphic Overrides, but that combination unfortunately does not address complex interactions like presence of openings in a wall during a particular time span, which is otherwise addressed by Renovation Filter.
The Renovation filter already implements a narrow idea of was/is/will-be, but a TIME factor would allow for creating user-defined "milestones" (example: completion of construction phase), where each milestone would automatically recognize the timeline of a particular element, and be able to automatically assign a was/is/will-be status similar to Renovation.
Any View in the View Map would have an extra "Timeline" group of settings: when in time are we viewing the model, how far into the past, how far into the future, alongside Layer Combination, MVO, GO, etc.
It's been emphasized before that BIM should also factor the lifespan of a building, so what I'm proposing isn't totally out the official party line.
Well, I hope it makes sense.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
