Date Formatting - File Instead of System Specific
Guru
Hi all,
This wish is for the formatting of the autotexts <SHORTDATE> and <LONGDATE> to be definable within the file rather than be dependant on the users system settings.
https://community.graphisoft.com/t5/Project-data-BIM/Date-in-change-manager/m-p/597474
Ling.
2 Comments
Karel Landa
Yes, definitely agrre.
You can work around this in template and pubsliher with another autotexts.
Something similar should be done for decimal divider ("." or ",")
Guru
The problem is that you cannot use the <DAYOFMONTH><MONTHNUMBER><YEARSHORT> autotexts to reformat dates that are already using the <SHORTDATE> <LONGDATE> formats such as those from several GS objects or indexes. I do not think there is anywhere that you can use %d%m%y anywhere either.
Status
Submitted
with 7 Votes
Wish details
