Demolished Windows & Doors should leave an Empty Opening
JPugh
At present, a demolished window or door leaves no trace in the proposed view, but in reality it needs to be infilled with new construction (which may differ from the make up of the original wall).
Using a renovation filter to 'show' the removed windows would mean showing everything else too, and perhaps in an undesirable representation.
At present we insert a 'New' empty opening in place of the Demolished element, in order to have a hole that can be filled with a new wall.  This works ok, but seems like a workaround rather than a reflection of reality, more steps than should be necessary, requires workarounds in schedules so the 'new' openings don't show, and is non-associative to the dimensions and position of the original window, should they need to be amended.
Please could there be a setting to allow demolished opening objects to remain 'visible' but replaced with the Empty Opening?
2 Comments
MaScht
option to choose either "keep opening" or "close opening".
Often a former window-opening in a concrete wall is closed by masonry and fairly often in a different thickness.
IF "colse opening" THEN
- choose building material
- chose wall thickness
Best regards
Eduardo Rolon
Agree with @MaScht
Status
Open
with 55/200 Votes 3.636363636364%
Wish details
