Fast Work Environment Switching — Like Fast User Switching on macOS
Pedro Melo
Work Environments (WEs) in Archicad are powerful, but switching between them is slow, disruptive, and buried in menus. For users who wear multiple hats — modeling, documenting, managing BIM standards, scripting, etc. — it should be possible to switch WEs instantly, just like Fast User Switching in macOS.
The goal is to make changing WEs feel effortless and immediate, so users can jump between task-specific setups without friction.
Proposed Features:
  • A dropdown menu, toolbar button, or dockable palette for one-click access to saved Work Environments.
  • Option to assign keyboard shortcuts to instantly load specific WEs.
Why This Is Important:
  • Reduces Friction: Switching WEs currently takes too many clicks and breaks workflow — this would make it instant.
  • Supports Multi-Role Users: Most users don’t just model or document — they do both (and more). Each task benefits from a tailored interface and shortcut setup.
  • Streamlines UI Management: No more wasting time rearranging palettes or hunting for tools depending on what you're doing.
In Summary:
This feature would make Work Environment switching feel natural, fast, and task-oriented — empowering users to adapt their UI to what they’re doing in real-time, with zero friction. It’s about giving Archicad the flexibility modern workflows demand — like fast user switching, but for power users inside a single project.
6 Comments
I don't think it can get much quicker than this - 2 clicks.
Pedro Melo
😂 Didn't know about that one.
Still the UI could be improved. Maybe make this available in all pre-defined WE or even better a fixed UI item (a menu, other?)
It's in the menus as well.
If you are creating your own custom Work Environment, then you have to make sure you add it to the menus and tool bars if you are not basing your WE from a default Graphisoft one.
Pedro Melo
I know, but it's cumbersome... like so many other great features in Archicad, it's not visible or sufficiently developed. Seems half baked.
If it is buried too deep in the menus (4 clicks), you can create your own menu and have the WEs just 2 clicks away.
You can't create a keyboard shortcut for the WE list, but you can create one to open the WE dialogue itself.
Pedro Melo
You win 😂
Status
Open
with 0/200 Votes 0%
Wish details
