I'm about to write a similar post. Both suggestions should be implemented. I don't think this would be such a huge problem from a developer's perspective. However, it would be very useful in everyday use. I wrote a GDL object for myself for this, but it would be much easier if this could be set directly in the fills.
Gábor
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
