Hide hotlink master layer button in Quick Layers
Mats Knutsson
As the subject says...
4 Comments
@Mats Knutsson,
Could you clarify this wish?
Quick Layers, as in the Quick Layers palette?
So, you would like a new button added to the Quick Layers palette? And if you have an element selected and it's part of a Hotlinked Module, clicking this button would hide the Hotlink Module's Master Layer, effectively hiding the whole Hotlinked Module?
Mats Knutsson
@Laszlo Nagy  yes exactly.
Karel Landa
I think that managing the layers of hotlinks should get more attention.
Using quick layers pallete often cause that I hide the whole module when eg. only one wall is selected. Then I have to manually turn it back on in the layers settings 💁‍♂️
Mats Knutsson
@Karel Landa that should not a problem unless you work with smaller projects and have grouping activated. Our use case is when grouping is deactivated and I just want to hide the whole hotlink by selecting any "layer" within" the hotlink. This would be very useful.
Status
Submitted
with 9 Votes
Wish details
Product
Labels
