I am still trying to understand what exactly does the letter E stand for between M and P.
The most direct workflow that an Architect can intergrate the MEP would probably be to design the electrical grid in matters of functionality within a space.
Switches, sockets etc. in connection with lighting fixtures is the simplest design process that an architect can do.
Inserting those electrical elements in an architectural floorplan is a common thing.
The decision of sockets and switches is mainly an architectural process because it is related to the distribution of lighting and electrical devices around the house taking in consideration the room distribution, the room functionality, the furnitures, the devices etc.
The architect decides about the height, the type, the colour etc.
For the moment this need is covered only with certain addons or certain library objects.
Why is to hard to optimize this basic function of a basic electrical installation around a simple house via the MEP addon?
MEP addon should first cover the basic needs of an Architect and then move forward to a more engineering functionality.........
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
