One of the features in Archicad that I use regularly is the Minimal space feature coded in most objects and Doors. I have a problem with this valuable tool as it is underdeveloped and a pain to use. A perfect example of not paying any attention to any practical feedback and then historically ignoring the tool after release. Based on my experience, I see the following deficiencies:
1. The tool need be extended to ALL Objects. At present some of the most critical like, furnace, fireplace, heaters, etc., do not have this feature. The lack of which can cause code compliance problems.
2. Need provide a tutorial to allow the user to add this feature to user created objects. The feature mostly uses a standard macro that could be added to any object assuming the proper configuration.
3. Allow the space feature to be turned on/off on a individual object basis, based on some criteria.
4. Allow minimal space criteria to be configured in the schedules for all Objects.
5. Likewise, allow listing of spaces for each Object in schedules.
6. Allow color coding of spaces on an Object basis.
7. Allow listing of all Objects within a zone – not just a count
8. Provide a minimal space on/off shortcut key independent of the MV. Also, a toggle icon.
9. Provide minimal space criteria for critical Objects, similar to the stairs tool. Provide out-of-bounds listing warnings.
10. Provide a reset to defaults.
11. Collision detection between spaces and elements – color code collisions
12. Add 3D Minimal space display
Probably others could add more. I made a video describing my solution to automating the setting of spaces using a Excel worksheet , a Python script and an AddOn to change the Library parameters. The files can be download from my GitHub site referenced in the video. Not thoroughly tested – use at your own risk. I would be interested in any comments or additional application using the files. If you are interested, please give the video a ‘like’, if not. Please give a ‘dislike’. Your likes/dislike are the only way to communicate what features we might want to see expanded for Architecture. Please participate and not just complain.
The video link is:
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
