Key improvements needed:
- Direct edit of modules in place.
- Fix labels positioning problems in mirtored/flipped modules.
- make it optional to add the embedded library to the .mod files (prefer not to add) or filter out embedded libs if they already exist in host.
- Make it possible to schedule the Module. Not just components of it. (I want to schedule which bathroom type goes into which apartment type)
- Make it possible to schedule and label mirrored modules.
- Modules currently remember their source storey. Bad idea, if I want to insert a new storey between 2 existing negative module storeys. Solution needed so a new storey does not mess up the placement of all modules
- Option required to Not show .mod files as openable projects in Archicad start-up window.
Typically, it us a bad idea to open mod filesvand edit in separate Archicad, because it will surely mess up attributes. Not to mention, that if you open stand alone mod-s, there is no way to see the context.
Please also refer to (and vote) the below Module related wishes, where - as requested - I separated this complex wish into several parts.
Make Modules Great Again - 1: In Place Module Management
Make Modules Great Again - 2: Embedded Library Management
Make Modules Great Again - 3: Attribute Management
Make Modules Great Again - 4.0: Schedule Modules
Make Modules Great Again - 4.1: Schedule Mirrored Modules
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
