Not a high priority item, rather one of those annoying little bits.
Currently you can choose to show the elements originating from the Master Layout as a chosen single color in the Work Environment / On-Screen Options. Now if you have a title bar with colors, or you just simply want to see a realistic preview of your sheet design, you might want to go back and forth with this option. This really belongs to View/On-Screen View Options, not hidden in Work Environment with no direct command option. Some people may even want to add a keyboard shortcut for quick and easy switching. Thanks!
